LabWindows/CVI
Network Variable exists on another PC
Using Network Variable library there are two functions (CNVProcessIsRunning and CNVVariableExists) that can be used with local variables (i.e. Published on the same PC). As a matter of fact the machine name can't be used as an input to these functions.
Are there some functions that can be used in the same way for variables published on a different Pc?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,797 Views)
you need this functions to handle network variable:
CNVCreateBufferedWriter
CNVCreateScalarDataValue
CNVPutDataInBuffer
CNVCreateSubscriber
CNVGetScalarDataValue
(3,728 Views)
You can use the Browser class functions like CNVBrowse to browse for variables on the network. They are low-level functions and a little more difficult to use than other functions in this library but you can see their usage in the implementation of the open source NetworkVariablePopup function in toolbox.c.
(3,717 Views)
Hi Mohan
I used CNVBrowse and I've been able to find all the existing processes and variables over the network, but how can I determine if that processes are running or not?
Vix
Using LV from 7
(3,692 Views)
Hi vix,
Only network variable 'processes' that are 'running' are visible to the CNVBrowse API. 'processes' that are 'stopped' do not show up in the browsing API. So if you are able to browse to a process/variable, then that variable is available for use.
(3,681 Views)
