01-25-2008 07:38 AM
01-25-2008 11:15 AM
01-28-2008 03:38 AM
01-28-2008 10:59 AM
That's correct, assuming that it's a project template that you're creating, and not a file template. In my previous reply, for the sake of simplicity, I only provided the directories for project templates, and assuming that you're using Windows XP. If you're creating file templates instead, the directory is \Documents and Settings\All Users\Documents\National Instruments\CVI\File Templates.
Luis
02-08-2008 12:51 PM
02-08-2008 01:35 PM
| [[FILENAME]] | Filename plus extension. |
| [[FILEBASENAME]] | Filename without extension. LabWindows/CVI obtains this value from the File Name control in the New File from Template dialog box. |
