LabWindows/CVI
Next CVI 8.5 update/fix
Can anyone give an estimate when the next CVI update will be?  The overlapped graph/chart control bug is holding up at least two of our software updates that have been fatally cripped by it... but 8.5 also fixed some bugs that we had been working around so going backward isn't a favorable option either.
Greg
Message 1 of 8
(4,004 Views)
It will probably still be a couple of months, or so. If that is too long, let me know, and we can try to create an unofficial patch for you.
Luis
Message 2 of 8
(3,995 Views)
It would help me a lot if you could provide an unofficial patch for the overlapped-chart-draw bug.  I have two difference charting applications with end-of-march deadlines and I'm not looking forward to explaining why most of the features have been disabled waiting on updates".  I will likely be able to send updates when the official fix is released.
Greg
Message 3 of 8
(3,988 Views)
I agree with gvan. The overlapped chart bug is killing our ability to get new releases out to our customers.
Martin
Certified CVI Developer
Message 4 of 8
(3,969 Views)
Martin, Greg,
We'll have a patch available in a couple of days, or so. When we do, I'll post a link here in this thread.
Luis
Message 5 of 8
(3,928 Views)
Martin, Greg:
You can find a self-extracting download for the patch here. Let me know how it works out.
If you want to deploy an application to another computer, make sure you rebuild any distributions that you might have already built, and make sure that the distribution includes the CVI run-time engine. When you do, it should automatically include the patched version of the run-time engine. If you are not using the CVI Create Distribution tool, then you'll need to explicitly run this executable on any computer where you want to run your application.
Even after you install the patch, the CVI ADE's About Box will continue to show its version as 8.5.0.279, but if you navigate to c:\windows\system32\cvirte.dll, this file should indicate that its version is 8.5.0.280.
Luis
Message 6 of 8
(3,878 Views)
Thanks Luis,
The fix looks like it working.  I've got my charts back!.
Greg
Message 7 of 8
(3,850 Views)
Hello all,
I just found out that the link that I posted earlier is probably temporary. It might not be available in a few days. If it isn't, please try this link instead.
Luis
Message 8 of 8
(3,817 Views)
