LabWindows/CVI
Ni-SCOPE 2 channel measurement
I am trying to do 2 channel measurement using NI-SCOPE but cannot change the default other channel.
I tried setting the attribute to set to a different channel other than channel 0 by doing this
niScope_SetAttributeViString (handle, otherChannel, NISCOPE_ATTR_MEAS_OTHER_CHANNEL, 0)
but it does not work. It is always using channel 0 as the other channel.
Any suggestion what I am missing?
(2,566 Views)
probably it is better to post in the Digitizer forum, here: https://forums.ni.com/t5/High-Speed-Digitizers/bd-p/150
(2,551 Views)
Hi !
Did you check the FetchForever  .prj project ? this is a shipping example on CVI
(2,530 Views)
