LabWindows/CVI
Nidaqmx controls cause resource leak
I have some string controls on my UIR, which I convert to daqmx device and channel selection controls using the functions like NIDAQmx_NewPhysChanAICtrl, NIDAQmx_NewDeviceCtrl, etc. So far so good..
Upon exiting my execution (which I started from the cvi ide) the resource tracker warns me about 8 different thread lock objects remaining in memory, and all point to those daqmx control functions (which are called exactly 8 times). Photo attached 🙂
Is NI aware of such a leak? Is it solved in later versions of CVI?
I am running win7-64 bits, CVI 2012 sp1, Daqmx 15.0.0f2 (as seen from MAX)
S. Eren BALCI
IMESTEK
(3,944 Views)
S. Eren,
 This is Ali from National Instrument's applications engineering. I did some research on recorded issues and I don't think anything is recorded for this memory leak.
Would you happen to have a smaller version of your code that showcases the same leak? This is something I can definitely look into and see if I can recreate (if so I can document) on my end.
Ali S.
Applications Engineering
(3,912 Views)
Hi Ali,
It is easy to reproduce. I have 8 string controls on the panel. 2 of them are converted with NIDAQmx_NewDeviceCtrl, 2 are converted with NIDAQmx_NewPhysChanCICtrl and 4 are converted with NIDAQmx_NewPhysChanAICtrl.
(These functions are in the daqmxioctrl.fp instrument)
Attached is a small project with 1 device and 1 channel control. Upon exit you can see the remaining open resources in the Resource Tracking window.
S. Eren BALCI
IMESTEK
(3,900 Views)
Accepted by topic author ebalci
It seems you forget to discard controls (as all NI samples do).
Simply add these two lines before DiscardPanel(panelHandle);
NIDAQmx_DiscardIOCtrl (panelHandle, PANEL_STRING_DEVICE);
NIDAQmx_DiscardIOCtrl (panelHandle, PANEL_STRING_CHAN);
Carlo A.
Megaris
(3,893 Views)
Wow, I really do not know how I missed that..!
I am using CVI for a long time and first thing I did when I was warned by the resource tracker was to look for such a discard function. But I have no idea why I could not find it.
I was so convinced (and surprised) that those functions did not exist.
Anyway, thank you for looking into the matter.
Cheers..
S. Eren BALCI
IMESTEK
(3,891 Views)
