LabWindows/CVI
No Driver Error when including Traditional DAQ in CVI 9.0 Distribution Kit
I have some legacy code (CVI 6.0) that I wanted to upgrade recently.  The biggest reason was the ability to add the device drivers to the distribution kit.  When I installed the software on a new machine I got a No Driver Error when doing a CounterStart call .  In the past that error meant that I had not included CVI support when I installed Traditional DAQ.  Since it was installed as part of a distribution kit I can't see what elements were installed.  I assume since it was included as part if a CVI distribution kit that CVI support is automatically.  How can I get rid of the no driver error?
CP
(3,621 Views)
Hi, Clutch
try this, build->distribution->managing distribution -> build step. and in drivers&components Table, you can select the driver you want to include.
see graph below
hope this can help !
B.R
Gerry
(3,605 Views)
That is what I have done.  It installs Traditional DAQ but, it doesn't include CVI support for Traditional DAQ.  I can run the msi file for traditional daq inside my installer seperately and then I can choose to add CVi support.  I can't seem to find anyway to add that option as a default setting for the installer.
(3,588 Views)
Accepted by topic author ClutchProgrammer
Unfortuantely, there is no way to have tDaq included in a CVI build installer with CVI support.  R&D is aware of the issue.  For now, the workaround is to modify the tDaq installation and add CVI support.
For more information please see this KB.
(3,572 Views)
