LabWindows/CVI
No display of Menu bar
Hello
On one of the workstation after running the setup there are NO display of menu bar (but other applications like MS word, Notepad etc. are showing menu bar properly) while on other workstation all application are displaying  menu bar properly. Also checked with resizing of display screen but no luck. Also tried by re-installing the application but same behavoir observed.
With regards
Rakesh
(2,881 Views)
Hi Rakesh,
I assume you created your own custom CVI menu bar that you add to your panel at run-time after your "setup" phase and the menu bar is not displaying?  You are probably calling either LoadMenuBar or LoadMenuBarEx. The Word and Notepad menu bars have absolutely no affect on a CVI menu bar so we don't have to focus on that.  Did this ever work or did it just stop working recently?
Maybe the menu bar you are loading is in a different UIR file and you didn't bring that over to the target computer?
Does this behavior happen on multiple computers?
A little more clarification on the symtpoms and setup would help.
Best Regards,
Jonathan N.
(2,873 Views)
