09-23-2005 10:46 AM
09-26-2005
06:06 PM
- last edited on
11-10-2025
11:07 AM
by
Content Cleaner
There are a lot of factors that can introduce noise into your measurement system, so it is mostly a matter of narrowing things down until we can elimintate the source of the noise.
If you short the inputs to channel one together (to effectively measure a 0 voltage), what are your readings?
Which pins do you have your signal connected to?
Does the noise only appear on channel 1, or on other channels as well?
Does the noise appear when you read in the measurement in a test panel in Measurement and Automation Explorer?
I would also take a look that this article that goes over field wiring and noise considerations, it has a lot of useful information.
