LabWindows/CVI
Non imidiate update of table rows
Hello
I think i've read somwhere that it is posible to fill in a number of table rows without updating the screen imidiatly.
The update should be done when all cells/rows are initialized in order to speed up the screen update.
Is this just my imagination ?
(3,221 Views)
Per:
Have you looked at SetTableCellRangeVals()?  It has less overhead than individual calls to SetTableCellVal().
Or if you need to update individual cells (if they're not in a block so you can use a range of cells),  you can use SetTableCellAttribute().  Here's a note from the help on SetTableCellVal():
Note   This function updates the displayed value immediately. Use SetTableCellAttribute with ATTR_CTRL_VAL to set the control value without immediately updating the displayed value. Because of the difference in behavior, SetTableCellAttribute with ATTR_CTRL_VAL is generally faster than SetTableCellVal. However, if the table control in which you set the cell value is the active control in the panel, SetTableCellAttribute with ATTR_CTRL_VAL displays the value immediately.
(3,212 Views)
In addition to Al suggestions, you could consider hiding the table before you need to update it and display it again after update has finished: if you don't call any ProcessDrawEvents or ProcessSystemEvent while updating the table, it will not disappear from the screen.
(3,194 Views)
