LabWindows/CVI
NonLinearFitWithMaxIters does not give correct results for phase
...so in order to reproduce your results the value of w and your y-array would be required
Message 11 of 14
(2,111 Views)
Dear,
Please you find attached the data, ch1, and ch2, the waveforms of the two singals which I calulated the phase.
For each (ch1,ch2), I noticed in the folder the phase which I have found using NonLinearFitWithMaxIters  function.
I have here 4 samples of data (8 arrays)
for data 1, the phase I have found between ch1 and ch2 =0.279942
for data_2, phase=-5.564697
for data_3, phase=0.300977
for data_4,phase=-5.554908
I calculate the phase between ch1 and ch2,.i.e; phase of ch1-phase of ch2 in degree.
For each array I have 1252 points (the size of the array v_array).
For w= 2*pi*40.68 MHz=2*pi*40.68*1e6 (the frequecy of the two signals is exactly 40.68 mega HZ).
Could you please tell em why the function gives me these two groups of phase?
Message 12 of 14
(2,104 Views)
I am wondering if you played the sample data that I have sent to you, and if you have found any explication for the issue of NonLinearFitWithMaxIters function?
Message 13 of 14
(2,091 Views)
I did not forget about the issue, but since I need to write the code to read your data etc. myself (you did not provide a test project) and since I do this in my spare time turnaround times are not immediate. I am interested in this question myself so I will have a look but I can not promise when I will be able to do so.
Message 14 of 14
(2,089 Views)
