LabWindows/CVI
Numeric Control: disable textbox entry in order to use in/decrement buttons only?
Hello there,
Is there a way to disable editing of the textbox in a numeric control so that the user can only see the value when he uses the in/decrement buttons?
I know this could be achieved by using an numeric indicator and two buttons in a while loop. However I run into problems when I use this approach together with my event loop. Therefore I thought there might be an easier way by doing it directly with a numeric control. Is this possible? Thanks for your help.
(3,263 Views)
Some elements in your question make me think you are programming in LabVIEW: if this is true, you should repost this question in the appropriate forum.
If I'm wrong and your develpment environment is CVI you could attach a callback to the control and swallow (i.e. return 1) the keyboard events:
int CVICALLBACK theNumericCallback (int panel, int control, int event,
                               void *callbackData, int eventData1,
                               int eventData2)
    switch (event) {
        case EVENT_KEYPRESS :
            return 1;
            break;
        default:
            break;
    return 0;
(3,258 Views)
Yes sorry you are totally right. I put this in the wrong forum. I will be more careful next time.
(3,230 Views)
