LabWindows/CVI
Numeric slide bug?
I have not seen reference to this problem elsewhere on the board, so I hope I am not asking a common question.
I am currently running CVI 7.0 (393) on Window 2000 XP Professional (not yet installed the upgrade to 7.1 for project schedule reasons).
I have added a Classic-Style Controls -> Numeric -> Horizontal Slide (using classic controls for legacy reasons). It is to represent a 14 bit DAC so it's properties are set up to show an unsigned short int, minimum value 0, maximum value 16383. Everything looks ok while designing in the .uir However, when I start to debug the application, the slide is displayed with a maximum value of 16382 (i.e. 1 less than it should be). The slide does move to a maximum value of 16383 (as shown in the digital display part of the slide), it is just the maximum value label that is wrong.
I have tried to work around this with the following code
SetCtrlAttribute (panel, PANEL_DAC_SLIDE, ATTR_MAX_VALUE, 10000);
which displays the maximum value label as 9999 (again, 1 less than expected).
Has anyone experienced this problem and know what the solution is? Is it simply a case of upgrading to 7.1? Or am I having some sort of finger trouble?
(4,551 Views)
Hello James,
I was unable to reproduce this behavior on my machine in CVI 7.0 or CVI 7.1 with the 7.1 runtime engine. Are you using a Windows 2000 machine or a Window XP machine? Also, would it be possible for you to include a UIR that demonstrates this behavior? I would suggest updating your runtime engine to the most recent version to see if this corrects the problem.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,531 Views)
@Wendy L wrote:
Hello James,
Thanks.
Sorry about the confusion, I am using Windows 2000.
My problem seems to have cleared itself up: I have moved several elements of my panel to a new separate panel, at which point my slide max limit (still on the original panel) started showing the correct number.
I will re-create my original panel / UIR. How do I include a UIR in a post?
(4,512 Views)
The .uir file extension is on the list of extensions that will soon be added as a valid file type for the forum posts. For now, you can rename you file to a different file extension or add it to a zip file and post it that way.
Wendy L
(4,491 Views)
Wendy L,
I am currently unable to re-create this bug, either by putting the elements moved to the sub panel back into the main panel or by creating a test panel of similar complexity.
For the time being, I'll put it down to finger trouble on my part. If I see a similar problem again, I'll get back to you. In the meantime, thank you for your time and attention.
James.
(4,474 Views)
Hi James,
Might it may have something to do with the pixel dimensions of the slider? Try playing with the width and see if the 'bug' disappears/re-occurs.
John.
(4,333 Views)
