LabWindows/CVI
NweCtrl, Tooltips,InstallCallback, DiscardCtrl, causes a RuntimeError in DebugMode
if i build dynamic controls in my uir with NewCtrl,
add tooltips SetCtrlToolTipAttribute , install a ctrlcallback with InstallCtrlCallback and later i would
remove the ctrl with DiscardCtrl , in debug mode a non fatal runtime error occured (err 13 , wrong control id). i have added the function call to
the toolbox-sample list.c , so i can reproduce the error there too.
i haven't found a error in my software, what's
the reason for this error ? did anyone know this problem ?
(3,611 Views)
This usually means you are trying to discard the control with a wrong
panelHandle.
Try to compare the panelHandle passed to NewCtrl with the panelHandle
passed to DiscardCtrl.
volker wrote in message news:<50650000000800000090ED0000-1079395200000@exchange.ni.com>...
> call to
(3,611 Views)
Volker,
as far as i looked upon your added code, the problem will most likely be located in the way you discard the control. you are discarding the control in the following function:
int CVICALLBACK ChangeItemCallback (int panel, int control, int event,
void *callbackData, int eventData1,
int eventData2)
switch (event)
case EVENT_VAL_CHANGED:
DiscardCtrl(panel,iNewCtrl);
if (g_myList)
UpdateUIR (panel);
break;
return 0;
referring to the CVI-help, DiscardCtrl has to be used:
LabWindows/CVI does not allow you to call DiscardCtrl from the callback function for the control, except in res
ponse to a commit event.
please review your code and uir if this could be the reason...
- Norbert B.
NI Germany
Norbert
Expert: Geometry
(3,611 Views)
