LabWindows/CVI
ODBC connection remains open after disconnect
in my application I use 2 ODBC connects to 2 different ODBC drivers.
My problem:
When I close one connection (with DBDisconnect), the connection on the database remains open until I close the second one.
Is this a known behavior?
Is there a way to force the closing or to make it independant of the other connection?
Regards
Fred
(3,048 Views)
Accepted by topic author FredOnNI
As ODBC connections are not inherently included in the CVI environment, I looked up the DBDisconnect function and it says that the DBDisconnect function disconnects the last connected ODBC database. So it is expected behavior.
Ian M.
(3,019 Views)
