LabWindows/CVI
ODE in LabView/CVI
Does anybody know if it is possible to use the ODE (ordinary differential
ecuations) VI (or in general another VI) from LabView in LabWindows/CVI?
Thanks!
(3,467 Views)
> Thanks!
Transfer from LabVIEW to CVI is not possible (unless you make it an exe and
call it that way)
Transfer from CVI to LabVIEW is possible if you make it a DLL and use the
Call Library Function.
Kevin Kent
(3,467 Views)
Hi...
Yes... two ways
You can use Labview 6.0i to create a DLL and then export the function for CVI... not to hard but there is not much documentation for the parameters...
Or use ActveX wizard to build an ActiveX container Labview Type library... After that yuou will have acces to most of the fuction ... But it is kind of hard because of the Variant data type... and other stuff that is a bit wicky for ActiveX programming
Best Regard
Steph
(3,467 Views)
