LabWindows/CVI
OPC: Data socket returns 0x80040154 (REGDB_E_CLASSNOTREG)
The CVI OpcClient-Demo says "Class not registered", but the OPC server is running (on localhost) and a non-CVI OPC client can connect to it. Tried with 9.0 and 2010SP1 Runtime, it's Windows XP Pro 2002 SP3.
Can someone give a hint where to look, at the CVI part or the server? Thanks.
/* Nothing past this point should fail if the code is working as intended */
(3,806 Views)
Accepted by topic author CVI-User
SOLVED
I just installed the runtime and copied the exe to the target. That doesn't work.
After I build a distribution with NI DataSocket component and installing it the copied OpcClient works. Even after uninstalling said distribution...
(3,795 Views)
