LabWindows/CVI
OPC UA architecture
long topic to read in details but I'm quite sure the solution is inside.
I need to make an OPC UA client to connect an OPC UA server.
Is there now a validated version, using NI libs or third party lib?
If so, wan I find somewhere a tutorial, a summary, of integration method?
PS: we already have an application with OPC-DA (sill a few issues with server on another machine) but now have to migrate to -UA, which is very different.
Message 41 of 57
(4,942 Views)
you can jump to my message and follow the procedure that i've done following vix instruction.
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 42 of 57
(4,935 Views)
thanks, we will have a look.
It would be great if NI provide directly a compatible solution to such a standard.
Message 43 of 57
(4,928 Views)
there is but only for labview http://sine.ni.com/nips/cds/view/p/lang/it/nid/215329
Message 44 of 57
(4,926 Views)
Thanks for the tip.
May be possible to wrap this labview kit to CVI? I know it will be inefficient but may work.
(out ot technical topic answer)
and what about NI but not Labview users? They are not in the view of marketing?
Message 45 of 57
(4,923 Views)
i don't know if it's possible to wrap, never tryed
Message 46 of 57
(4,916 Views)
Hello to evryone,
to keep the board as clean as possible I suggest you to open a specific topic for every specific question.
I asked for an OPC UA library some years ago.
Maybe it's time to add an official product suggestion so that the users can give kudos.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 47 of 57
(4,915 Views)
Here is my product suggestion.
Feel free to give kudos to the idea if you need this library.
Vix
Using LV from 7
Message 48 of 57
(4,905 Views)
I tried to create a project with open62541 library (0.2).....
I tried to put .c .h files in a new project, but I have problem with datatypes (int8_t, etc. where are they defined???)
and with missing files (ua_types_generated.h, and others)
Does anyone have successfully compiled the library in CVI?
Message 49 of 57
(4,516 Views)
Message 50 of 57
(4,491 Views)
