LabWindows/CVI
On the right click menu "Go to Definition"
Hello NI,
let's assume a project with three source code files.
File B defines a variable
double x [ 4 ] = { 0 };
File A and file C use this variable according to
extern double x [ 4 ];
Now I am editing file C and right click on a line with
 x [ 2 ] = ... and choose "Go to Definition". Where is the cursor supposed to jump to?
In my case it jumps to the extern double definition in file A.
I would have expected it to jump to the original definition, i.e., the double x in file B, or, at least, to the secondary definition in the same file, but not to the secondary definition of some other file...
Also this post on a very similar issue has never been answered...
Thanks!
(2,547 Views)
HI you have to select Debug option instead of release option,in developer window
Regards
Germanbrain
(2,496 Views)
Thanks for your comment but I have to say that I am using the debug configuration...
(2,485 Views)
