LabWindows/CVI
Open External application
Please Help!!
How can I send information and receive from external command prompt from my cvi project.
I want to run an external command prompt, a code that's is not mine, to send information to this command prompt, the make my program hit enter at
the command prompt and then receive back information from the command prompt.
Thanks in advanced.
(4,937 Views)
Hello DSFDF,
What you could do is open the external process, redirect the input and the output. Then, you could write directly to the input and read the output of the process.
= Nelu F. || National Instruments.
(4,911 Views)
This is what the external executable file do
I have a program the's when I run it the program open a cmd (Command Prompt )
and I can enter manually variables, press enter the program calculate for me something and then present on
the cmd the calculated variables.
how I whant to use the external executable file
my question is how to write a code in C thet's will open this program send every time different variables and then recive back from the program the calculated variables??
thanks in advanced
(4,868 Views)
Hello DSFDF,
I think this resource will help you.
(4,836 Views)
