LabWindows/CVI
Open GL Mouse wheel events
I have started to use the Open GL instrument driver.
I would like to use the mouse wheel to zoom in and out on the Open GL graph but there are no MOUSE_WHEEL_EVENT send when the Open GL control is active.
Is that normal behaviour?
To overcome this issue I tried to use another mouse event (for example: EVENT_MOUSE_POINTER_MOVE) to change the focus to another ctrl but it is not working. I can not change the focus programmatically once the focus is on the Open GL control.
Is there a way to overcome these problems? Is there a way to use the mouse wheel to zoom in and out on an Open GL control (like with the ActiveX 3D graph)?
Note: You may perhaps ask why I do not use the ActiveX 3D graph instead the OpenGL instrument driver?
It's because I have to display 3D objects consisting of a large bunch of triangles and as far as I know it is not possible to do that easily with the ActiveX 3D graph
Regards
Bertrand
Message 1 of 1
(4,418 Views)
