LabWindows/CVI
Open pdf file from application menu
I am looking for a way to open a file using the associated Windows application, i.e. if the file is a *.pdf file use Acrobat reader, iif it is a *.txt file using notepad.exe or whatever application is associated to that file type. If this isn't possible with Labwindows then how would I go about launching an external application without hardwiring in the exact location of said application, i.e. launch Adobe Reader without hard coding in the path to the current version that is installed.
(3,822 Views)
This is actually quite simple. Use the OpenDocumentInDefaultViewer () function in the Programmer's Toolbox.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,820 Views)
Martin Fredrickson
Test Engineer
Northrop Grumman
San Diego, CA 92128
(3,820 Views)
Thanks. As it happens I just managed to search on the right combination of words and found this function.
(3,817 Views)
