LabWindows/CVI
Open txt file
I need to open all txt files in a folder (one by one).
Using this function "OpenFile ("c:\\Users\\file1.txt", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);" i have to give the name of each file but wanna open all the files without giving the name then extract values from each file and put them in an excel file.
How can i make an automatic test without giving the names of all files?
Thanks a lot.
(4,105 Views)
You can build up a loop with GetFirstFile and GetNextFile to extract all the file names, then handle them one-by-one in the loop.
(4,100 Views)
