LabWindows/CVI
OpenComConfig -1 queue size?
I'm having issues with a USB comport adaptor on a Windows 7 PC. The program hangs sometimes when reading, writing, or closing the port.
My application is in CVI Version 8.1.0. This occurs running as executable and in the environment. When the crash occurs in the environment it says a nondebuggable thread has caused a fault at address 68647163, the address is always the same. The CVI environment and program cannot be closed, the only way to exit is to turn off the PC;s power.
This only happened on Windows 7 PC, on XP with the same adaptor it works fine.
I've read a couple posts which suggest using OpenComConfig with a value of -1 for the input and output queue size to eliminate problems. Here is one thread with this suggestion:
http://forums.ni.com/t5/LabWindows-CVI/Serial-communications-with-Windows-7/td-p/1253850/highlight/t...
When I do this, I get an error from OpenComConfig: -114 Requested input queue size must be 0 or greater.
How is it possible to specify -1 as the queue size? Is this not available in 8.1?
(4,412 Views)
Accepted by topic author kmagas
If you carefully read the help for the command, setting queue size to -1 is permitted only for the output queue, in order to skip one level in the operating system and write directly to the port. In put queue size must always be declared as a nonnegative number.
Regarding your error the reason could lie at the driver level: have you installed the most recent release of the usb-to-serial adapter for your OS? I ma using several of those adapters both on XP and iwn7 with succesful results, but I need to use different drovers depending on the OS I install the device onto.
(4,404 Views)
Thanks for the quick answer. I was setting both queue sizes to -1. Setting only the output q size to -1 seems to have solved our problems.
(4,359 Views)
