LabWindows/CVI
Out-of-bounds pointer argument (before start of memory block) CVI 9.0
After upgrading to CVI 9.0, the debugger (debugging level standard)  reports   "FATAL RUN-TIME ERROR:   "Array.c", line 167, col 54,     //thread id 0x00000974:   Out-of-bounds pointer argument (before start of memory block)"  for a standard call to the uir: Previous versions of CVI have not reported this and I cannot understand why CVI 9.0 should..
The call looks like this:
     SetCtrlVal(hPanel, PANEL_STRING, stCatLimits[i][j][k].szLimitTxt);
A workaround that works:
     sprintf(szMsg2,"%s", stCatLimits[i][j][k].szLimitTxt);
     SetCtrlVal(hPanel, PANEL_STRING, szMsg2);
We have included a file that can be compiled using CVI 9.0.
Best Regards,
Jan
(3,697 Views)
I've created a bug report for this (#134586). I'll post an update back to this thread when the problem has been investigated.
Mert A.
(3,686 Views)
It turns out this is a bug with initialized, multidimensional arrays of structs or pointers. When a debugged program accesses members of such an array, the runtime protection compares the pointer address against the wrong pointer bookkeeping information. For example, when you're accessing stCatLimits[0][0][1].szLimitTxt, it's doing a little pointer arithmetic to calculate the address of the szLimitTxt field. It comes up with the correct address, but then checks that address against the legal memory range of stCatLimits[2][4][4] (instead of stCatLimits[0][0][1]). Because that pointer is well before the later struct's memory chunk, you get a "Out-of-bounds pointer (before start of memory block)" error. One other quirk is that the first element in the array is unaffected by the bug, which is why your first error occurs on element [0][0][1].
The next maintenance release will likely be the first chance we have to fix this bug. Until then, I can suggest a few workarounds to avoid this problem.
1. Set the Debugging Level (in the Build Options) to "No run-time checking". This requires no changes to code, but of course gives up the benefit of the runtime checks.
2. Call SetBreakOnProtectionErrors() in specific files or in the body of certain functions to locally avoid breaking/terminating execution when these errors are generated.
2.  Wrap item accesses in a macro that throws away the bad pointer checking information:
#define BUG_FIX(type,arrayItem) (*((type *)(void *)&(arrayItem)))
SetCtrlVal(hPanel, PANEL_STRING, BUG_FIX (CATLIMITS, stCatLimits[i][j][k]).szLimitTxt);
 I'm very sorry for the trouble, but I hope this helps.
Mert A.
(3,652 Views)
Thanks for adequate answer. As a beta tester, I should have discovered this at an earlier stage. I didn't run that piece of code in debug mode.
Jan
(3,634 Views)
