LabWindows/CVI
PC System minimum demands to run CVI 2017 smoothly
I would like to know if the system I have has the minimum demands to run CVI 2017 without getting unpleseant delays. It is used mainly for debug and tiny project changes.
I meant there is often a hint from the software company for a minmum suggested PC System.
Could not find it yet in the NETPS02-2_System_.png.
(2,670 Views)
Accepted by topic author G4bandit
See here
(2,664 Views)
It seems to me that your system should be able to handle your projects: I'm currently working on CPUs a bit worse than yours and my projects are not so small.
(2,657 Views)
A check of the link revealed that I need a higher .Net Version. (Installed 4.0 need to have 4.6.2)
When I start CVI 2012 it works everything without delays, like clicking on CVI, something happens directly. (i5-6440HQ 8Gb RAM)
When I start CVI 2017 on the machine with the posted sys info, - clicking waiting and waiting about 1 Minute(?) at least 30sec.
So I think on a i5 instead of i3 it would work better.
(2,652 Views)
