LabWindows/CVI
PC memory buffering
Hi all,
I'm using CVI 8.0 with USB6210.
I have planned to write 2 separate programs and requested to run at the same time. The first program was used to generate a sinwave continuously and transfer the data into the pc buffer.  Another program was used to read the data from the pc buffer which were generated by the first program.
I have tried a lot of ways such as created buffer using WriteToPhysicalMemory and ReadFromPhysicalMemory but it doesn't work in 2 separate program.
Any suggestions?? Thanks.
Chew.
(3,713 Views)
See the example code at C:\Program Files\National Instruments\CVI70\samples\sdk\sharemem
JR
(3,707 Views)
Thanks..
Chew.
(3,702 Views)
