LabWindows/CVI
PC104 direct I/O access with Labwindows/CVI real-time
I am evaluating the Labwindows real-time stuff  for my company to see if we can use it for our own embedded control system.
A big problem I still have is the apparent absence of the possibillity to directly access i/o ports to control 3d party boards or our own i/o boards.
Our embedded system is based on a PC104 cpu  - Digital Logic's MSM800SEV if you must know - and what I want is just as simple as writing or reading a few bytes to or from a few i/o address of our I/O board as I am able to in our DOS solutions. I consider the PC104 stack a desktop PC, seeing that everything else works as intended.
I know that an inp and outp are available within CVI, but they only work onder Windows because of some NI driver that makes it happen; however that driver is not suitable - as mentioned on forums - for use in the real-time environment.
Any suggestion I have seen so far boils down to some VISA or IVI solution using tools like the I/O assistant, which only work for NI boards and the rare 3d party board - that we are not using -.
So....
How can I use Labwindows/CVI real-time - though it seems to present itself as Labview real-time -  to directly access the i/o ports from our own PC104 I/O boards at e.g. address 0x300?
(4,154 Views)
Hi Ajabo,
The first note to mention is that you can convert a PC-104 processor board to a real-time target as long as the hardware meets the system requirements  of the ETS RTOS.  If you meet that criteria, that's a good first step.
Now, I going to assume that your PC/104 device is a PCI version (PC/104 Plus), which means that you can treat it like any PCI or PXI device and use NI-VISA to communicate with the card. The Using the VISA Driver Development Wizard and NI-VISA to Register-Level Program a PXI/PCI Device unde... tutorial and the Configuring the NI Real-Time Environment and NI-VISA to Recognize a Third Party Device tutorial discuss these topics.  Also, the Porting a Windows Device Driver to the NI Real-Time Platform tutorial is something you should look at. This article describes porting an existing C driver to RT and it happens to even include C code snippets. The first article talks about LabVIEW RT but this process woudl be the same for CVI RT.
The above article on porting a driver mentions that LabVIEW cannot respond to callbacks and therefore instructs the user to call viWaitOnEvent to detect an interrupt event and respond appropriately.  I think this is driven by the article's focus on creating a driver that can be wrapped by VIs and called from LabVIEW. In your case, you will be working in CVI and so your option woudl be to register a callback with viInstallHandler that will be called by an NI-VISA thread when an event occurs.
The last article I wanted to mention is the Developing a LabVIEW Real-Time Driver for a PXI, cPCI or PCI Device turial which is helfpul.
Your best option is going to be to use VISA.
Hope this helps!
Best Regards,
Jonathan N.
(4,143 Views)
Hello Jonathan,
Thanks for taking the time looking at my problem.
And sorry, but there is that danger of assumptions again; we can not use PC104 plus, since the I/O boards we use only have the PC104/ISA bus. This bus is much simpler and allows even me to design PC104 I/O boards.
What I am actually looking for is a way to let machine instructions like OUT DX,AL and IN AL,DX work, which in the end are the instructions that the processor must use to access 'normal' I/O boards.
Of course with the machine running in virtual mode in stead of real mode, there has to be taken care of some access management, which what I think could be perfectly placed in a simple low overhead generic I/O driver that allows me to perform bus I/O under LabWindows real-time just as I have always been used to with DOS.
Real-time operations is all about I/O, so it would be strange if it were not possible to access I/O boards from within LabwindowsRT.
This will probably make your suggestions so far void, so I will await new suggestions.
AJ.
(4,121 Views)
Hi ajabo,
You can use NI-VISA to perform register-level programming to access those specific I/O addresses on your boards.  You can still use the article I mentioned entitled Porting a Windows Device Driver to the NI Real-Time Platform in this case.  You can find detailed information on register-based communication in the NI-VISA Library topic in the CVI Help. In the CVI Help, you can find that topic in the Contents tab under Library Reference >> NI-VISA Library >> User Reference >> Register-Based Communication.
Also, I'm not familiar with the Measurement Hardware Driver Development Kit, but this might be of some use to you.
The final note is that NI-VISA is supported on RT so we are in good shape there.
Hope this helps!
Best Regards,
Jonathan N.
(4,081 Views)
Accepted by topic author ajabo
I found it !!
(well, someone else did it for me, but I tried it to see that it works)
In order to access the I/O directly use the inp/outp that are exported by the pharlap kernel.
// define some handy types
typedef int (*T_EtsInp)(unsigned int);
typedef int (*T_EtsOutp)(unsigned int, int);
// undefine existing macro's (which do not work for Embedded Real Time anyways)
#undef inp
#undef outp
// declare inp and outp (byte versions)
T_EtsInp   inp;
T_EtsOutp  outp;
At process attach or some other convenient spot, but before the actual use of the functions.
  // Get module handle
  myHandle = GetModuleHandle("ph_exec.exe");
  inp = (T_EtsInp) GetProcAddress(myHandle, "EtsInp");
  if (inp == NULL)
    printf("Unable to get proc address for EtsInp");
    return 0; // or other finishing action
  outp = (T_EtsOutp) GetProcAddress(myHandle, "EtsOutp");
  if (outp == NULL)
    printf("Unable to get proc address for EtsOutp");
This allows the use of real I/O without any need for any driver and there seems to be minimal overhead as well.
(3,785 Views)
