LabWindows/CVI
PCIe-6321 frequency measurements
I am trying to use a PCIe-6321 to perform a simple frequency measurement (800-2500hz).  Are there daqmx functions for frequency measurments?  I tried some of the CVI examples but they throw error messages.  Is there an example were I can measure frequency on one of the analog inputs?
(3,674 Views)
Are you tied to the analog channels? Couoldn't you drive your signal to a counter input? This will make frequency measurement an easy task.
(3,670 Views)
I'm not familiar with this card.  It would be nice in NI had a few CVI examples on how to wire/program the card.  You would think NI would have a simple Frequency measurement function to handle the measurement on an Analog input channel.  The documentation indicated anolog inputs and then that some of them are ctr inputs?  its a little confusing!
(3,667 Views)
Your card have both analog inputs and counter inputs; they behave differently and for each of them there is a set of examples that explain the basic measurement types together with cabling.
Search with the example finder (Help >> Find examples... menu item) with "counter/timer" keyword and you'll find the examples you are looking for. Also looking for "frequency" drives you to the same examples.
(3,661 Views)
Have you tried the example projects "Measure Frequency" and "Measure Voltage" in "Analog In" folder?
(3,627 Views)
