LabWindows/CVI
PXI-2568 switchDevice, relay names
I do not have the hardware (PXI-2568) installed on the development system and my never have it on this system. How do I acquire the PXI-2568 “switchDevice” name and  “relay” names for the target system with out installing the board? At this moment it is unclear if we will be using NI-DAQmx, or  NI-SWITCH.
(3,177 Views)
Hi speakerdriver,
If you are trying to write code for a device that you don't have installed on your development system, you can always simulate it in Measurement and Automation Explorer (MAX). For more information on the relay names you can look in the NI Switches Help under Devices » NI PXI-2568 » Hardware Diagram. I hope this information helps.
Message Edited by Jordan D on 07-18-2007 08:42 PM
Jordan D
Applications Engineering
(3,158 Views)
