LabWindows/CVI
PXI-4462
i have the PXI-4462 card and i will read the frequenz and the value from an audiocanel.
In the example i did't find an example.
Can me help someone?
(3,250 Views)
you must first read in your signal.
http://zone.ni.com/devzone/cda/epd/p/id/583
You get an data array.
You must analyse that array to get the frequenz and amplitude.
To do that you can use first the AutoPowerSpectrum()-function and then the PowerFrequencyEstimate()-function.
(3,231 Views)
