LabWindows/CVI
PXI-4462
Can someone supply me with the formula used to determine the A1 Gain Accuracies.  I see the spec is +/-0.03db, but I am having difficulties relating that tolerance to the actual low/high limit on the calibration performance test data.
(2,915 Views)
Hello Wunder,
Thanks for your post!
There is a knowledge base that talks about that Gain Accuracies that you are looking for. See the link below:
Absolute Accuracy of Dynamic Signal Acquisition Devices \
Let us know if this helps you and I wish you the best on your applications!
Cheers!
Corby_B
http://www.ni.com/support
(2,897 Views)
