LabWindows/CVI
PXIe - 8240
O an going to use PXIe - 8240 via Labwindows / Cvi. But I could not find the way. Especially, which driver requires. I can see at the Max but could not see the test panel.
Could you help me?
(3,239 Views)
From the link below you can download needed drivers.
https://www.ni.com/en/support/downloads/software-products/download.pxie-8240-firmware-and-additional...
And here is the users manual that would be helpful for you.
https://www.ni.com/docs/en-US/bundle/pxie-8240-seri/resource/377048a.pdf
Best regards.
(3,210 Views)
Thank you for repply and interest. Actually, I download this driver and I can see the module at NI MAX, but I can not see the test panel. I think there is no test panel feature.
I do not understand especially which driver requeire to Labwindows/CVI. For example, NI-DAQmx, NI IMAQdx etc.
By the way, I have studied before these documents and I do not understand.
Thanks.
Best regards.
(3,203 Views)
Check-out the Getting started document by link below. I think it would be helpful.
https://www.ni.com/docs/en-US/bundle/pxie-8240-getting-started/page/getting-started.html
Best regards
(3,170 Views)
Hı,
Thank you again for your repply.
I check out this document for five or six times, but I have still no idea how I configured via Labwindows/Cvi . For instance which command or library to initiliaze the device.
Best Regards.
(3,165 Views)
