LabWindows/CVI
Panel Handle retrieve using its constant name or id
Is it possible to dynamically retrieve the panelhandle, already loaded from a library call, using the name or the uir ID?
I need to change some attribute of panel control and doing that panel handle is mandatory.
Message 1 of 8
(4,457 Views)
I am not aware of a function that returns the panel handle when given its ID. But you can put them (panel handles) in a global array as you load them, indexing by their ID and then retrieve back when needed.
Hope that helps
S. Eren BALCI
IMESTEK
Message 2 of 8
(4,448 Views)
I'm brand new to CVI (two weeks, if that) so take this with a grain of salt... What I've been doing is having each panel in it's own .uir file, and then having the corresponding .c file contain a "XXXXInit ()" routine that sets anything needed up, and returns the handle.
Then, in my main.c I can have things like
PanelSomethingInit ();
PanelElseInit ();
They return the panel handle, so I can preserve them in main.c if I need to (as well as error check).
Then, each also has a GetHandle function:
somethingHandle = PanelSomethingGetHandle ();
elseHandle = PanelElseGetHandle ();
I can obtain that easily anywhere I need it, and it keeps me from polluting variables by using globals everywhere. This also keeps all my UIs modular so I can drop them into any other program I need to, easily.
My coworker solved this earlier with a function that looks them up based on a pass-in define:
int ReturnHandleFunction (int panelID)
   switch (panelID)
      case PANEL_MAIN:
         return panelMainHandle;
         break;
...etc… He can then get any handle he wants by calling "handle = GetHandleFunction (PANEL_SETTINGS);" or whatever.
I really thought there should be a function in CVI that uses the #define created by the UI editor and returns the handle, but I haven't found it (if it exists).
Message 3 of 8
(4,406 Views)
The panelHandle I need is out of my scope. The Panel is loaded using a library function and the handle is static in that library so no way to retrieve it through the library exported function.
Only the name of the panel and its ID are in my hands.
Message 4 of 8
(4,389 Views)
This should be the effective answer... but it isn't....
Message 5 of 8
(4,385 Views)
Accepted by topic author brug71
Effectively such a function does not exist at present... and it will never exist, I suppose.
Simply consider that you can have more instances of a panel loaded in memory, each of them identified with its proper handle; as if you wanted to identify an individual car by its model type only: you can't! You need the actual plate number (i.e. the panel handle) to identify a single car among all the others of the same model.
Message 6 of 8
(4,376 Views)
Yeah, the library author should have at least provided a way to get that handle. How do you have the ID? Is it in a library-provided header file? I wonder what the use of that is, if there's nothing you can do with it.
Actually, I'm still new to this … when you say ID, what do you actually mean?
Message 7 of 8
(4,368 Views)
I agree with you, the plate example is the definitive answer.
Message 8 of 8
(4,360 Views)
