LabWindows/CVI
Passing floats from CVI to TestStand.
 I have compiled the below into a .dll using CVI. It converts the hex input to a floating decimal. Calling this .dll from TestStand 3.5 returns the decimal number 15. The output from the CVI I/O window is 15.380562. The input is "417616C8". In TestStand when theFloat is declared as a unsigned 32-bit integer it returns "15" If assigned a 32-bit Real Number (float) it returns "IND" Any ideas why I cannot return the whole 15.380562?
Thanks in advance,
Steve
long __declspec(dllexport) HexToFloat(char HexInput[])
    float theFloat;
 sscanf (HexInput, "%x", (int *) &theFloat);
 //scanf("%x", (int *) &theFloat);
 printf("Hex input 0x%08X, %f\n\n", *(int *)&theFloat, theFloat);
 return theFloat;
(3,407 Views)
You have defined the function as type long. Try using float (or double) instead.
    double __declspec(dllexport) HexToFloat(char HexInput[])
JR
(3,396 Views)
Well that was easy. Thanks....
(3,394 Views)
