LabWindows/CVI
Pb retrieving sorted data from Table in SQL.
I get problem to retrieve data in the right order from table in database SQL.
See code attached: code.png
I want to sort data according to ID number And then to retrieve those data and fill out a ring control in the right order "descending" .
But i got always ID 2 instead of 1. See attached  picture : control.png
it seems that the select statement (see under) is not woking properly. But it is working well in a query in Access DataBase .
//Select statement
   hstmt = DBActivateSQL (hdbc, ("SELECT * FROM %s ORDER BY ID DESCENDING",szTableName));
   if (hstmt<= DB_SUCCESS) {ShowError(); goto Error;}
Some idea ??
Lionel.
Message 1 of 9
(6,605 Views)
I know that this is a really stupid suggestion, but I cannot think of anything else: Have you tried DBFetchNext instead of DBFetchRandom ?
Message 2 of 9
(6,591 Views)
I have tried but get the same that with DBFetchRandom.....
Message 3 of 9
(6,580 Views)
Hi Lionel,
Could you please try adding a single quote around the string identifier, like this:   '%s'
Does it work?
I also recommend the LabWindows/CVI SQL Toolkit Reference Manual, especially chapter 5, for additional information on the library functions.
http://www.ni.com/pdf/manuals/370502a.pdf
Robert P-F
Message 4 of 9
(6,557 Views)
Does it work?
I have tried "  the string identifier, like this:   '%s'" but it is not working ... Query works in access but dont seem to works in CVI ...
I have also worked  a lot with the 'LabWindows/CVI SQL Toolkit Reference Manual'  but without sucess.
Regards.
Lionel.
Message 5 of 9
(6,549 Views)
Hello Lionel,
According to the document Robert linked, the prototype of DBActivateSQL() is:
int statementHandle = DBActivateSQL (int connectionHandle, char SQLStatement[]);
For the 2nd parameter(SQLStatement), you're sending:
Probably your intention is to substitute %s with szTableName, but that's not what it happens.
By using comma operator, ("SELECT * FROM %s ORDER BY ID DESCENDING",szTableName) is evaluated to szTableName, so you call is equivalent to:
hstmt = DBActivateSQL (hdbc, szTableName);
In order to substitute %s with szTableName you need to first build the string you're passing as the 2nd parameter:
char query[512];
sprintf(query, "SELECT * FROM %s ORDER BY ID DESCENDING",szTableName);
hstmt = DBActivateSQL (hdbc, query);
Message 6 of 9
(6,515 Views)
I have tried your suggestion but it still not working ...
Message 7 of 9
(6,508 Views)
Can you debug the program and see that query contains the correct string.
What type is szTableName?
Message 8 of 9
(6,505 Views)
I have resolved the problem by using DBBindColChar function !!! See attached code.
Thank you for your help !!
Best regards.
Lionel.
Message 9 of 9
(6,499 Views)
