LabWindows/CVI
Peak detection function for sawtooth waveform not working properly
I am using peakdetector function for finding peaks in a sawtooth wave. The peaks it detects is 2 units higher then the actual peak. But when i do the same thing for sine wave it detects the peaks properly.
Can anyone please tell me why am I having this problem and how to resolve it? Any help would be greatly appreciated. Thanks in advance :smileyhappy:
(3,778 Views)
Me again Smiley Wink
Could you provide the data set showing the issue and the respective code fragment?
(3,777 Views)
My code is as follows:
SawtoothWave (1281, 10, 1/128, &phase, sig);
PlotWaveform (panelHandle, PANEL_GRAPH, sig, 1281, VAL_DOUBLE, 1.0, 0.0, 0.0, 1.0/128, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
PeakDetector (sig, 1281, 0.0, 3, 0, 1, 1, &count, &peak_loc, &peak_amp, &peak_secon);
for(i=0;i<count;i++)
*(peak_loc+i)=*(peak_loc+i)/128;
PlotXY (panelHandle, PANEL_GRAPH, peak_loc, peak_amp, count, VAL_DOUBLE, VAL_DOUBLE, VAL_SCATTER, VAL_ASTERISK, VAL_SOLID,1, VAL_GREEN);
It works when i do the same thing for sine wave.....
(3,773 Views)
In order to reproduce it one would also need the initial value of phase...
Anyway, using your line
yields constant values, i.e. no maximum, simply because 1/128 equals zero; so probably your code looks different... : How many peaks did you get, zero?
Using SawtoothWave (1281, 10, 1.0/128.0, &phase, sig); instead I obtain 10 peaks; the first location is 59.507812500000000 - rounded to an integer this yield the correct index 60...
(3,770 Views)
With that line i got a sawtooth wave having 10 cycles. It dtects  all the 10 peaks but at an amplitude 2 units higher the the actual peak. I have attached a picture of what I got...
(3,765 Views)
I see  - and also get those numbers. I would assume that this is due to the underlying algorithm which is based on fits of a quadratic polynomial; sharp edges as found in the sawtooth function result in large derivatives and seem to mislead the algorithm; you may take comfort from the fact that most of these built-in functions have limitations... As documented in this forum I am using my own PeakDetector, so you're not alone Smiley Wink
(3,744 Views)
