LabWindows/CVI
Plagued by "Types do not match" error
I'm using LabWindows 5.0 on WinXP Pro.
I've created an IVI driver, and within it created an attribute of type ViReal64. I've created a test program in which I use a numeric input component to get a value into a variable which is declared to be type ViReal64. I then call an IVI user function passing in my value. That function, in turn, calls Ivi_SetAttributeViReal64() and passes in the value. The next thing I get is the "Types do not match" error. I can't for the life of me figure out why! BTW, the same thing happens if I use _SetAttributeViReal64().
Any hints on where else I can look for the fix to this bug? TIA for any help ...
(2,924 Views)
Hi BA,
Would you mind posting a small example of the code you use to generate this error? I know that ViReal64 is just another term for type double, but for the standard interface in VISA. So, I would like to see if possible the code you are using and also the IVI driver you're creating. Thanks!
Jeremy L.
Jeremy L.
(2,924 Views)
