LabWindows/CVI
PlotDigitalLines cannot plot 11 lines and ~6000 points. Why?
I would like to display 11 lines of a bus on a digital graph control. I have approx. 6000 points of each line and when I call PlotDigitalLines the program stops and says "General protection fault". Is there a limitation how many data can be displayed on a digital graph control?
(4,007 Views)
Only guessing here but 11 * 6000 just exceeds 65535. Looks like that's your limit, then.
JR
(4,003 Views)
It can not be, because I tried to display a reduced set of 11 lines and 4000 points, and it caused the same error.
(4,000 Views)
Normally you get a General Protection Fault when you read or write beyond the end of an array. Maybe your array-size does not correspond to the size-information you pass to the Plot-Function?
Maybe you could attach an example with which I could reproduce the error ?
(3,971 Views)
I found an answer. Formely the data to be displayed were located in a dynamically allocated array. With this array the PlotDigitalLines function crashed every time. Now I have created a sufficient static array and with this type of storage it works fine. Thanks everybody for trying to help me.
(3,953 Views)
