LabWindows/CVI
PlotIntensity Out-of-memory error
I am using PlotIntensiy to display a playback of data in three graphs. During the playback, after running through around 100 updates with no apparent program memory increases, memory usage increases rapidly (using Windows Performance Monnitor) until an out-of-memory error occurs for PlotIntensity under debug mode. Any ideas as to the cause of the problem?
(3,339 Views)
Hi jimmek,
I have a couple follow up questions for you.  First, which version of CVI are you using?  Secondly, how much data are you sending per iteration.  Lastly, what type of data mode are you using (e.g. smooth update, retain or discard)?
Additionally, it would be helpful if you could post a small snippet of code that reproduces the issue.
Cheers,
Kelly R.
(3,318 Views)
