LabWindows/CVI
PlotStripChart function
I am using "PlotStripChart" function to express variables. I would like to show two variables(data range is pretty different.) in one chart.
I tried to show each variables with traces but it was hard to see the values because of the different range of data.
Is it possible I could set active both Y-axises(Left and Right axis) for StripChart and bind the variables to each axis?
Thank you,
Insuk
Message 1 of 19
(7,928 Views)
I think I found the indirect way by setting the axis scaling. If you have any better way, please let me know.
Insuk
Message 2 of 19
(7,922 Views)
You can enable the right Y-axis and set the strip chart with two traces. Next customize e.g. trace 2 to use the right Y-axis. From this moment on, when you PlotStripChart with an array of two values, the first one refers to left axis and the second one to right axis.
Message 3 of 19
(7,909 Views)
This is how you set trace #2 to use the right axis:
Message 4 of 19
(7,902 Views)
Hello Roberto,
Thank you for answer. But I still have difficulty to see the trace#2 value.
If I use right Y axis, it should have the independent scale for the value. Right?
If the YLeft = 100 and YRight = 0.0001, then they should have each auto scale and show the graph by the range.
My Right Y axis values seems to follow the left range and hard to see the smallest Y axis value.
Should I set up for this one? I also could not see the right Y Axis values. Do I need to set up for showing Right Axis value?
Thank you,
Insuk
Message 5 of 19
(7,886 Views)
This is how to show and set the right Y-axis scale:
Message 6 of 19
(7,882 Views)
Hello Roberto,
For making sure, let me attach the uir file setting and the part of my program.
Do I need to call "SetCtrlAttribute(DisplayHandle,Chart[idx].chartCtrl,ATTR_ACTIVE_YAXIS,VAL_RIGHT_YAXIS);" whenever I update chart?
I tried that but it did not work either.
The code:
PlotStripChart(DisplayHandle,Chart[idx].chartCtrl,PlotBuf[idx],2,0,0,VAL_FLOAT);
The attachments:
1. trace setting
2. my uir apprearance
3.running result
Message 7 of 19
(7,882 Views)
Thank you though I did that before asking that.
Insuk
Message 8 of 19
(7,880 Views)
Let me give more codes for making sure. The following code is repeating every 1 sec.
PlotBuf[idx][0] = dataF; //This value for trace #1
PlotBuf[idx][1] = Chart[idx].sampleVar; //This value for trace #2
Thank you,
Insuk
Message 9 of 19
(7,872 Views)
No, ACTIVE_YAXIS need not to be calle before plotting. You should simply call PlotStripChart as you are already doing. But I noticed that in your uir3.jpg (running result) the right Yscale is not visible: are you sure you are using at runtime the same strip chart you customized in the UIR editor?
Message 10 of 19
(7,866 Views)
