LabWindows/CVI
PlotXY Vertical Bar
I have a problem with PlotXY Vertical Bar. My program gets datas every 30 seconds from a scale. I want to compare each value with a constant and display it in different colors depending on its value. The Graph sould display the latest 36 values.
If I use PlotXY with the attibute VAL_SCATTER then it is perfect. But VAL_VERTICAL_BAR is more optimal for my case. With Vertical Bar are the columns expanded. How can I avoid this Extension?
Message Edited by setirli on 05-23-2008 09:25 AM
Message 1 of 1
(3,156 Views)
