LabWindows/CVI
PolyFit() generates NaN coefficients
I am trying to do a curve fit using the CVI 5.0 Advanced Analysis Library
function PolyFit(), as follows:
status = PolyFit (x, y, n, order, z, coef, &mse);
The input x[] and y[] arrays are double precision and all of the sample points
have been scaled to fall between 0 and 1. There are about 3,000 sample points.
I have tried using a polynomial order of various values between 1 and 10,
but no
matter what I do, the output coef[] array, the z[] array, and the mse error
value
all contain NaN (not a number) for each of their double precision values.
The return value (status) is 0. If I plot the x[] vs. y[] data on a graph,
the
distribution of the data points is such that I can easily visualize a curve,
but
PolyFit()
is somehow not working.
I have read and re-read the description of PolyFit in the reference manual
and have searched the Knowledge Base and CVI newsgroup to no avail.
Any suggestions?
(8,163 Views)
I'm also having problems with the Polyfit but not the same as you however. I'ne lso seen NaN values but that's only when I did not initialize the array that I've created.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(8,163 Views)
