LabWindows/CVI
Popup massage
hello
How do show a popup massage whith number and not whith word
my code is:
char duree()
int D=0,tcp;
sscanf(tc, "%d", &tcp);
D=((n+1)+2)*tcp
return (D);
int D=0,tcp;
switch (event)
case EVENT_COMMIT:
tb[0] = duree();
MessagePopup ("Durée de l'essai",tb);
break;
case EVENT_RIGHT_CLICK:
break;
(2,998 Views)
Why not formatting the number in a string?
char a[15];
sprintf (a, "%d", duree());
MessagePopup ("Durée de l'essai", a);
This provided duree(); function returns an integer instead of a char (char is limited to -128 to 127, or 0 to 256 if unsigned).
...or else I didn't understand your question!
(2,989 Views)
Thank you all to your answer
I haven't think at this solution.
(2,984 Views)
