LabWindows/CVI
Power Spectrum Density
Hello
I have a problem with calculating the Power Spectrum Density (PSD). Unfortunately CVI does not have this funktion. So I must calculate the function by myself.
My customer explained me the algorithm and I managed it by calling the function "AutoPowerSpectrum" with some additional calculation (see below).
We tested the program and found out, that "AutoPowerSpectrum" always calculates RMS values. My customer wants to have real amplitude values.
Can someone here explain to me, what I must change? Must I implement my own "AutoPowerSpectrum" function, or is there a way to calculate it with CVI function?
Here is my code
AutoPowerSpectrum (gBuf, 2048, dt, ps, &df);
for (i=0; i<2048; i++)
ps[i] = fabs(ps[i] / df);
wher
e
gBuf is the input array
2048 is the count of
dt is the sample period in seconds
ps is the output array (single-sided power spectrum)
df is the frequency interval, in hertz, if dt is in seconds.
Thanks in advance
Stephan Gerhards
(3,688 Views)
Stephan:
You can use the CVI AutoPowerSpectrum function, followed by the SpectrumUnitConversion function (in the Advanced Analysis Library) to convert power spectrum into peak amplitude. See the help information for SpectrumUnitConversion for details on how to use it.
(3,688 Views)
