LabWindows/CVI
Pre-installation and post-installation commands
Is there a way to specify a list of pre and/or post-installation actions for a Distribution Kit created with CVI?
Before upgrading a program called 'B', I need closing an application called 'A', that must be re-launched after 'B' upgrade has been completed.
How can I get this result?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,250 Views)
Hi!
Is it possible to perform only pos-intallation actions.
You can find more infos here:
http://zone.ni.com/devzone/cda/tut/p/id/3212#toc4
have a great day!
MarcoMar
National Instruments Italy
(4,230 Views)
The link in your post refers to CVI 6.0, 7.0 and 7.1.
I've been using CVI 2009 SP1, so I read this document but it doesn't refer to launching post-installation executable.
Other ideas?
Vix
Using LV from 7
(4,221 Views)
This is from the document you referred to:
  • Launching a File after Installation—To launch a file automatically after installation, right-click the file in the Installation Files & Directories browser in the Files tab, select File Options, and enable the Launch After Installation option. The application is launched with the application associated with its file type on the target computer.
    JR
    (4,205 Views)
    I've completely missed because I've been looking into "Advanced Settings" section.
    Could you confirm that there is no way to perform some pre-installation actions? (Typical situation: close another application that is running on the target PC)
    Vix
    Using LV from 7
    (4,188 Views)
    Hi Vix!
    Why don't you create your own batch file that performs the required operations?
    Bye!
    MarcoMar
    (4,181 Views)
