LabWindows/CVI
Preprocessor command, assigned the variable and then compare the variable to int. How can I get around this?
#define ON 1
#define OFF 0
in seperate code
int variable = ON;
variable is globally define for that module.
in seperate code
if (variable == ON)
the complier errors off on the if (variable==ON)
My guess variable is variable in of type int and ON is a preprocessor command. Therefore it is a mismatch and complier doesn't like it. How can I get around this.
thank
Mahen
(3,676 Views)
Mahen
What is the exact message of the compiler?
I think the error is, that the compiler does not find the definition of ON
and OFF. Is it in the same source file?
If not, try to put it into an .h file and include it where you need it.
Stephan
"Mahen" schrieb im Newsbeitrag
news:101-50650000000800000011150000-982303670000@quiq.com...
> variable to int.
> #define ON 1
> #define OFF 0
> in seperate code
> int variable = ON;
> in seperate code
> if (variable == ON)
> c
> thank
> Mahen
(3,676 Views)
I think I have got it fixed
bool.h file
#define BOOLEAN int
#define TRUE 1
#define FALSE 0
Then you can define variable as
BOOLEAN variable
use the variable
variable=TRUE
If variable==TRUE
Thanks for your help
(3,676 Views)
