LabWindows/CVI
Preventing table cell selection highlighting
In looking at previous discussions on Table cell highlighting I see that there are not any attributes for the cell selector.  I think this is true for even CVI 8.0.1.   Attempts at making the table an indicator leads is a workaround solution that  could run into other problems.  A color attribute for this would allow the user to make the selection color transparent.  Any thoughts on this?
(3,252 Views)
Well, listbox controls have the ATTR_HILITE_CURRENT_ITEM which does exactly what we are looking for: determining wether the active element is highlighted or not, regardless the control is the active one or not or is hot or indicator. It would be maybe simpler using the same attribute for tables too rather than playing with the selection color.
(3,244 Views)
