LabWindows/CVI
Printer Initialization error
There is an error "Initialization of the DLL failed" (please find the snap shot of the error message in the file attached)occurring when I try to print a control("Text Box" contents) of the panel.
I am using the function PrintCtrl() and the printer is "HP LaserJet 4050 Series PCL 6".
I wanted to know if this printer works fine with LabWindows/CVI. If it does work, then what is missing out here.
thanks in advance for your support
Suman
(3,240 Views)
Some printer drivers have problems when you try to print from CVI, which is really not a fault of CVI. Have you tried to use another printer and see if it works?
(3,240 Views)
