LabWindows/CVI
Problem changing tab order on tab control
I have a tab control with a lot of numeric controls on it.  I want to set the tab order of all these controls.  I went to the tab control edit window, selected the "Tab Order" button at the bottom of the edit window and got the tab order edit window.  I changed some of the control's tab order, clicked OK and compiled.  I got a long list of compile errors, saying something like:  Redifinition of macro '<name of control>'.  These errors pointed to the #defines in the project.h file.
Is this a bug in CVI 8.1 or I am doing something wrong?
(3,505 Views)
Would it be possible for you to attach here the .uir and the corresponding header file?
Luis
(3,486 Views)
Cancel... cockpit error... had two .h files in that compile and did not realize it.
(3,457 Views)
