LabWindows/CVI
Problem creating ActiveX Automation controller
When I try to use the ActiveX Automation Controller Wizard from the tools
menu all I get is a dialog box saying "Looking for registered Automation
servers" then another dialog stating "Cannot find the file specified".
I can look at my .tlb through OLEView.
Does anyone have any ideas what file(s) can't be found? I just started using
this package so forgive me if I have overlooked something obvious.
Mike
(4,493 Views)
"Mike King" wrote:
>When I try to use the ActiveX Automation Controller Wizard from the tools>menu
all I get is a dialog box saying "Looking for registered Automation>servers"
then another dialog stating "Cannot find the file specified".>>I can look
at my .tlb through OLEView.>>Does anyone have any ideas what file(s) can't
be found? I just started using>this package so forgive me if I have overlooked
something obvious.>>Thanks,>Mike>>
Hi Mike,
The CVI ActiveX wizard , internally uses some forms or panels that are loaded
up when you start the wizard....sounds like for some reason that file has
got corrupted, and hence the appwizard cannot find it , and that's what the
message is..no way (that I know) out of this except a re-install of CVI....
Hope t
hat helps...
(4,493 Views)
